I need a circuit for my van which will trigger an alarm (beep of some sort) that i can connect with the factory temperature sensor. The circuit has to have an adjustable setting so that i can set it precisely a little bit above the normal running temperature.The existing sensor is a 'sender' type for an analog meter with thermometer pointer gauge scale.
I have found this link which have this voltage switch:http://autospeed.com/cms/A_2476/article.html
Would this work for my requirements?
Thanks!
Thanks!
