There is only one Motor which is operated by R-AC Relay, If the R-AC relay is energized the Relay Path Get closed and motor will get ON.
The Other Two Relays (R1,R2) are not connected with the motor. these relays operates only at DC voltages and these relay supplied DC voltage to Switch ON or Switch OFF the R-AC Relay.
From my Image The Relay R-2 output is going to R-AC Relay to make it ON or OFF. and again The Same R-2 Output is connected to energize R1.
If Output is coming in R-2, The R-AC Relay will ON and Motor Running. The Same R-2 Output will make R1 Energize and Opens the switch.
