Thank you so much, I study this and try to make everything work, I will let you know if everything works nice or if there is a problem!Forgot to answer the other part of your question: using a Bluetooth board as a test load is probably fine. It may have spiky, inconsistent current draw which makes it hard to get solid readings from, but it will definitely prevent the short circuit scenario.
Note that you still need different wiring configurations for current vs. voltage measurements. I'd suggest you read all three links in my previous post, just to make sure it really makes sense, before proceeding.
