Hello. I'm making a voltimeter-amperemeter using an atMEGA328P, L7805, LM358, LCD 16x2 and some other components.
The problem is that even though the LCD turns on, it doesn't show the code or at least the white squares it should, and when I move the potentiometer that goes with it it doesn't change the contrast.
I am completely sure it can't be the schematic nor the code since they were given by our professors, so they can't be wrong. The pads are fine, there are no shorts, and the components should technically be good.
I attached the schematic, pcb and code (the red pad doesn't cross the other pads, it's a cable that goes on the other side (single sided baord)).
I hope you can give me a suggestion.
