I am trying to make a stepper motor go in one circle using an ardurino uno but when i start the simulation, nothing happens.
is there a website you suggest that has all those things on it? im new to this and im not really sure what to do. Right now im using wokwi to make itI would think you need to drive the motor from a separate 5V supply, not the Arduino one as it cannot supply the required current.
And a 2200uF electrolytic capacitor on the motor 5V supply, close to the driver board will help keeping the supply clean.
I see you do not have the other 2 wires on the pot either.
its a potentiometerFor starters, what is the object attached with one wire to A0 ?
More info will get you more answers.
Good luck.......
Have a look at the link in post #11ok tysm. Do you know how to code it?
