Hie
I want to design a isolated flyback using LT8306 with 2 outputs. I am simulating with LTspice and I am having some issues with the output voltage. I want two different outputs of 20V and 5V from an input of 6V to 26V but instead I'm getting the same output voltage of 20V despite having different secondary windings inductance values. Because I did not know what the problem might be I decided copy a design that is already presented in the LT8306 datasheet and it suppose to give different voltage output but when I run it I'm getting also getting the same voltage output for both outputs.
Below is a screenshot of the design I copied from the LT8306 along with the LTspice model
