One question , i know this is a little childish question, but want to know what if a voltage of 33V is applied on a 24V ac motor? please don't underestimate this question....
that depends what you define as "necessary settings". If you include entering motor nameplate data and performing an autotune as "necessary settings" then the answer is yes.I have simple doubt , if we use a VFD of a particular company, and if we connect it to the motor output and supply input, other than giving our necessary settings, does it automatically works at consatnt V/f ratio and thereby limiting the starting current to safe value?
VFD's outputs are typically fully scalable, so as mentioned, your motor voltage is a parameter that modifies the output, meaning yes, your VFD will control the output for your motor ratings.I have simple doubt , if we use a VFD of a particular company, and if we connect it to the motor output and supply input, other than giving our necessary settings, does it automatically works at consatnt V/f ratio and thereby limiting the starting current to safe value?
by Jerry Twomey
by Jeff Child
