the water circulates back into the tank after it passes through the spindle motor
i just need an alarm to show if the water stop flowing.
like to bring on a warning light or horn.
what i think can also work is if i can mount a vibration sensor on the submersible pump.
to indicate if the pump stop working.
i am sure a temperature sensor can also work .
what will be the best way to add one?
and what will be the simplest way to do this. and what temp sensor do you recommend for this
paul
paul
