So a "source-follower" might have a problem turning on at low supply voltages?The first is a common-source circuit, the second is a source follower.
The first applies full supply voltage to the load, the second applies the supply voltage minus the gate-source turn-on voltage.
Yes.So a "source-follower" might have a problem turning on at low supply voltages?
To make sure that the intrinsic diode is always reversed biased (except in certain applications, such blocking reverse voltage to a circuit or when used as an active fly-back diode in a switch-mode power supply).If you look at how the intrinsic diode gets biased it will tell you the correct way to use the mosfet.
With low supply voltages, you can use logic level MOSFETs that have lower threshold voltages.So a "source-follower" might have a problem turning on at low supply voltages?
