praondevou
- Joined Jul 9, 2011
- 2,942
Yes and yes and yes.Are we all on the same page, that the freewheeling diode is the one across the motor (the diode that praondevou hand-drew)?
This diode is absolutely essential, and should be rated according how many amps you intend to run, as full motor current will be flowing through it when the mosfet is off.
The diode from source to drain doesn't do anything in the OPs design since it will not conduct as I showed a few pages ago. Even if it was, not necessarily one would need to add a diode because these MOSFETs have an intrinsic diode which however is not one of the fastest....
