Morley Wah Wiring Picture Needed
mcseaner
Joined Jan 21, 2010
3
Hi-
I recently bought a Morley Wah ProSeries Slimline Wah/Volume, and I think the previous owner tried to mod it and screwed up.
I can't read schematics, but if someone could open their pedal up and take a pic, I would be grateful to see the wiring.
Thanks,
Sean
SgtWookie
Joined Jul 17, 2007
22,230
What is the model number?
It could be any of these:
PDW
PWV
PWV-SS
PWV-0
PWV-II
Why don't you open up your box, and post a photo of it, both front and back?
mcseaner
Joined Jan 21, 2010
3
I've looked all over the unit but can't find a model number. But, it's a wah/volume. The input, output and power jacks are on the right side; it has one stomp switch on the bottom right-top for wah on/off and a dial switch on the bottom left for wah level.
SgtWookie
Joined Jul 17, 2007
22,230
The model number may be on the circuit board.
Random photos of a model different from yours may simply confuse you.
Also, Morley may have used components of the same values, but from various manufacturers - which may make the components appear to be different, even if they were the same model.
It would help us to help you the most if you could post a photo of the top and bottom of your stomp boxes' circuit board. It is hard to take good photos of a circuit board; the light needs to be diffused. Outside on an overcast day gives great lighting.
