Hi.
As usual, I'm repairing something and needs your help .
It's an smps type 1100W inverter. It had many problems and bad parts that I've fixed. Now I can measure high DC voltage at the HV capacitors, but there is no AC output. I measured the gate voltages of the high voltage MOSFETs using an oscilloscope and found no voltage... The ICs numbers' are erased and can't know them but the oscillator or HV MOSFET gate driver circuit is is connected with an IC as shown in the picture. I think this IC is something like a MOSFET driver or PWM IC. To know what it is let us first find a PWM/MOSFET driver 14-DIP IC with two outputs at pins 10 and 11. I didn't drew the whole circuit in that area...
NOTE: There is a mistake in the picture, it is a 14-pin IC and not 16 and the outputs are 10 and 11.
Any help, idea or suggestion is strongly appreciated.
Hazim
Hazim
