my $18 registers ZDA YDA and XDA are set as shown below (the ------ indicates the active setting; I've left the other registers our since they have no bearing on the problem I'm having)
D5: ZDA (z-axis disable)
0: enabled
1: disabled -----
D4: YDA (y-axis disable)
0: enabled -----
1: disabled
D3: XDA (x-axis disable)
0: enabled
1: disabled -----
Unless I've read the datasheet wrong, the above says " . . .. disable x and z axes, enable y axis"
When I run the monitor, I get readings for all 3 axes that vary sensibly as I orient the sensor in various orientations.
Is the "disable" applicable only to the process of deciding if data is ready to read, or should I not be seeing variation in the x and z readings?
0: enabled
1: disabled -----
0: enabled -----
1: disabled
0: enabled
1: disabled -----
