Only positive spike:I understand the positive spike, but why does the negative spike occur?
The current that is measured is the current flowing through C1, Yes I see that when the contactor opens the voltage drops slightly, , but that does not explain why the current goes positive and then suddenly turn negative , whenever the contactor is switched on?Just exactly where is that "negative spike" measured between?? When the contactor opens suddenly the voltage at the cap will drop a small amount because of the voltage drop across the 1000 ohm resistor. Recall that in this simulator, voltage sources can supoply infinite current because they have zero internal resistance. The simulator world is different from the real world.
