Microwave in Electronics
abhimanyu143
Joined Aug 25, 2014
211
Hello
I am just looking information about microwave engineering. I saw the some useful information on internet but still I am confused on some point.
1. what are microwave ? can someone tell me why we need to use microwave ?
as my understanding , microwave are electromagnetic wave with frequency between 300 MHz to 300 GHz, used in long distance communication
2. which circuits are the microwave circuit ?
I think microwave amplifier , microwave oscillator circuit are the example of microwave, example microwave amplifier amplify the microwaves
34,470
Microwave is the common name given to electromagnetic waves in the 300 MHz to 300 GHz frequency range you noted.
It was named for its wavelength (speed-of-light / frequency).
They are fundamentally no different than electromagnetic waves at other frequencies.
Microwave circuits are obviously those that operate in that frequency range.
We don't "need" to use microwaves, they are just frequencies used for many common applications such as Bluetooth, WiFi cell-phone networks, and of course the microwave oven.
21,228
I disagree. We need to use microwave communication for spacecraft, because microwaves pass through the ionosphere.
30,082
Hello
You've answered your own questions.
1) What are microwaves? A: Electromagnetic waves with frequencies between 300 MHz to 300 GHz.
2) What is a microwave circuit? A: Circuits that operate at microwave frequencies?
#12
That depends on whether you believe we need space craft.:rolleyes:
Personally, I think our satellites have done amazing things for our convenience, but I was raised where we had to go get water with a bucket, and I haven't quite moved into the 21st century.:D
Tesla23
Joined May 10, 2009
542
Agreed, but the window is considerably wider than this - it includes VHF/UHF. One of the main reasons we use microwaves here is because the VHF/UHF spectrum is either too congested on the ground or we need more bandwidth.
This looks about right, from http://www.spaceacademy.net.au/spacelink/radiospace.htm
There are in fact only two main windows of the EM spectrum that are open to space. One is the visible spectrum, as mentioned above, and the other is the radio spectrum. However, not all of the radio spectrum is useable for space communication. The available window spans from about 30 MHz to 30 GHz, although these are not absolute end frequencies.
Below 30 MHz, the ionosphere, at altitudes from around 100 to 500 km, absorbs and reflects signals. Above 30 GHz, the lower atmosphere or troposphere, below 10 km, absorbs radio signals due to oxygen and water vapour. Even between 20 and 30 GHz, there are some absorption bands that must be avoided.
cmartinez
Joined Jan 17, 2007
8,257
Cool diagram, but I didn't immediately grasp that the frequency axis was reversed.
Maybe it's because it makes more sense thinking in terms of wavelength instead of frequency? So in the diagram, the shortest wavelength lies at the left, and the longest at the right. I would've added a second line of labels to the horizontal axis to make the graphic clearer.
abhimanyu143
Joined Aug 25, 2014
211
sorry for late reply
1. I saw link https://en.wikipedia.org/wiki/Klystron
but I don't understand what is klystron, Is it component, circuit, amplifier, oscillator or tube ? can someone tell me what is klystron ?
abhimanyu143
Joined Aug 25, 2014
211
FFS read the first paragraph in that wiki article!
that means A klystron is a tube which is used as an amplifier or oscillators depend on power
as we know transmitter is used to transmit signal, receiver is used to receive signal using antenna, waves propagate in free space. i know how transmitter ,oscillator circuit make. but when its time to come in microwave I don't understand how they different from the basic electronics
I am confused because when we see the amplifier or oscillator in electronics term. first things come in mind that it can be circuit that made with electronics component such as transistor, resistor , capacitors .. etc, but when same words amplifier , oscillator use in microwave why its so difficult to understand,
30,082
The biggest difference is that at microwave frequencies you can no longer treat components as lumped elements or assume that the voltage on a wire is the same everywhere along the wire. The wavelengths are on the order of or shorter than your components and interconnects. So you have to treat everything as distributed. That greatly complicates the math. But it also opens up doors that were previously closed to the designer and no just how you layout a conductor on a printed circuit board becomes a filter or other circuit component. Of course, the reverse is true, conductors on a printed circuit board (or elsewhere) that you only wanted to be a conductor act as unintended filters or other circuit components.
Kermit2
Joined Feb 5, 2010
4,162
We always just called it RF plumbing. Waveguides and resonant cavities. Just a bunch of copper pipe through which we could push a full megawatt of microwave RF.
Feedhorns and reflector dishes, LNA's and (for our OP)
A klystron used as a local oscillator inside a special signal generator which simulated moving target echoes for use in signal injected troubleshooting of the video and doppler portions of the receiver section.
alfacliff
Joined Dec 13, 2013
2,458
satelites have used frequencies lower than microwaves for years. vhf, uhf, and even short waves. a lot of russian satelites used a frequency just above the 10 mhz frquency.
