My design uses an LM386 little audio power amplifier that has enough output current to drive many (20?) LEDs each with its own current-limiting resistor.what type of IC would be/have been ideal for this project?
but that's what I have. Why does the LM386 work for you but not for me?? -JoeMy design uses an LM386 little audio power amplifier that has enough output current to drive many (20?) LEDs each with its own current-limiting resistor.
In post #9 I showed how a capacitor from pin 1 to pin 8 boosts the gain 10 times.Why does the LM386 work for you but not for me??
there's not diode in that circuit; so i'm confused as to what you're getting at. -JoeIn post #9 I showed how a capacitor from pin 1 to pin 8 boosts the gain 10 times.
I also showed how to power and connect an electret mic.
Try it without the 1N4148 diode which might be connected backwards.
My circuit blinks an LED to the beat of the music. The LED is turned off without any music, unless you built it on a breadboard where all the long connection wires are antennas picking up radio signals and mains hum.question! how come this circuit doesn't work for me?? It's meant to modulate the IR LED and have a receiver demodulate it and pulse the signal through a speaker. it doesn't work, or at least, it doesn't work on a regular LED (i haven't tested out the full circuit with the receiving end). When I apply the 9V, the LED just turns on at about 60% power. Any ideas?? -Joe
We explained why the extremely simple circuit does not work.I got that circuit out of "101 Spy Gadgets for the Evil Genius", but haven't been having much luck for the circuits in the book. -Joe
