I'm a member of a formula student team and we are developing a vehicle control unit. One of the functions I'm working on is reading temperature in the water cooling system using a 10k NTC thermistor. I'm torn between using a resistor in series with a thermistor and measuring voltage across the thermistor, and using a thermistor in a bridge configuration.
We are aiming for accuracy and from what I can find the bridge configuration is more accurate, but I don't understand where that accuracy comes from? From the bit of math I did the accuracy comes out the same.
One benefit I found is that the heating of the whole circuit is offset when using a bridge configuration, but my resistors would be on a PCB while the thermistor is in the water cooling system, so it is only the thermistor that would be heating up meaning this would not apply.
The only benefit I can think of that would apply is when using same 3.3V we use to power ADCs to power the bridge, it would be easier to amplify the output signal to use the full ADC range.
Also, I know a capacitor is added to simple voltage dividers so the output is consistent across all frequencies, is that something I would need to implement for measuring something like temperature, and if so, how would I go about doing that to a bridge?
