Flip rodent on stomach (under anesthesia) with collection cup on scale below.Wondering how the TS/OP will make the rodent to urinate precisely "there"...
It's a medium that the urine is not miscible in. It's possible the droplets could just fall through air. The technology is called laser diffraction.Interesting idea. What is the purpose of the oil? Thanks.
Why not put the catch container at the end of a lever with a fulcrum positioned to give, let's say, a 10:1 mechanical advantage. The container will move 10 times farther with each increase in weight and will displace the scale 1/10 the distance but with 10 times the force. You will need a low friction bearing - particulary low static friction at the fulcrum. There are a few different ways you could apply that principle. Anyway it should get you out of the noise floor.As per Alec_t's suggestion, I am trying to identify individual drops with my 1000g/0.1g scale.
With some band-pass filtering, squaring, and smoothing I was able to get something usable. Only issue is that the height the droplets need to fall is 6-12" which is a bit much.
Yeah, probably one made of sapphire should do the trick. You could scavenge one from an old broken watch.You will need a low friction bearing - particulary low static friction at the fulcrum.
I was a little startled at the introduction to this thread.Hello,
I am interested in continuously acquiring load cell measurements with a resolution of 0.01g or lower. I need to be able to identify individual droplets of water (~0.5g) vs. time when added to the liquid container on the scale.
Thank you!
I need real-time continuous mass data.Why not weigh a baggie, collect urine, re-weigh baggie.
Or weigh cotton ball, collect urine with ball, re-weigh ball.
Yeah, I am considering getting a finer resolution scale.I would recommend the force-balance approach mentioned by RichardO (post #7) and elaborated on in the video posted by joeyd999 (post #9), but if you'd prefer something off-the-shelf you might consider the kind of scale used by reloaders to measure gunpowder. These scales usually have a resolution of 0.1 grains (1 grain = 1/7000 pound), or about 0.0065 grams. They're not expensive, and are available on MidwayUSA.com. Amazon.com also has some.
OK, I am sorry that my request was not clear to you."I need real-time continuous mass data."
No, you would need a continuously urinating rodent.
So, now you need flow rate?
Are there any other conditions? You know, specific gravity, temp, sugar, albumin, illegal drug screen?
It would be nice to know the complete setup, before offering solutions.
I shall retire from this one.
Weight on Earth.Please qualify the word mass.....substitute another word.
It's not so simple. Don't forget respiration and perspiration.If we knew the water intake, ....what's missing and leftover is the mass of the urine.
Thread starter | Similar threads | Forum | Replies | Date |
Need a small favor-Measuring Resistance | Test & Measurement | 1 | ||
D | Measuring small resistance change | Test & Measurement | 5 | |
S | Measuring small levels of capacitance | Test & Measurement | 7 | |
U | measuring very small current | Test & Measurement | 12 | |
U | Measuring small currents... | Microcontrollers | 2 |
by Jake Hertz
by Jake Hertz
by Jake Hertz
