bountyhunter
- Joined Sep 7, 2009
- 2,512
cant post in general this is a test
EDIT: sorry I thought I'd be able to delete, only off topic is working. its "500 internal server error" I cannot search the forum either for same reason.
EDIT 2: I can't even make another post here now so this is the only one I have to work with!
I'm trying to construct a 1/1000 voltage divider from a 25kv capacitor to a 0-100v panel meter. The below image shows what I have and the proposed dividers
http://i.imgur.com/1VPnKj8.jpg
What I don't understand is how the resistance of the panel meter is significant? I see people constructing the divider on the left and testing it by measuring across the second resistor, them I see circuits where the meter resistance is used in place of the second resistor.
Which one is correct? the divider on the left is easy for me to do with what I have on hand using 13.5W of resistors, for the one on the right I will have to buy.
http://www.newark.com/tenma/72-6530...4NspxnEk|pcrid|33870076941|plid|&CMP=KNC-GPLA
