Hi all
A friend of mine has a marshall valvestate vs265 amp that has had intermittent problems
Basically after a certain amount of time being on, a loud hum would come in and out through the amp , he said the previous owner had to get it repaired (mentioned resoldering stuff)
I found a schematic here, it does not appear to be 100% accurate (I will explain why soon )
http://www.amparchives.com/Amp Arch...state/VS265 65Wx2 2x12 Combo/vs265r_2x65w.pdf
heres what i found
*previous preamp tube had no glow to it , replaced
* friend had tried to resolder some of the points....whether it was him or from the previous repair some were in very bad shape , traces lifting or broken
I had to put silastic under the REG's and resistors because the trace had lifted so no ensure no more movement
I found REG 2 point 'com' to have had its trace completely broken, I managed to resolder it
I found REG 2 point 'I' to only have a circuit on one side and not passing through to the other , I resoldered this
previously R20,R21 and REG1 were getting VERY hot
since the resolder R20,R21,REG1 and REG 2 are all still very hot
now the amp has a loud pop when turning on and VERY loud when turning off
it seems the hum coming in and out has gone ....I do have the amp disconected fromt he speaker box so it is not getting vibration on it which may be part of the issue if there are bad solder joints
at the same time I don't want to leave it on for to long with the heat thinking it will fry these components
I noticed looking at the board, the O on REG 1 and REG 2 is going to C31 & C32 which are not shown in the schematic (seems to be C20 & C18)
I'm getting 41VDC on R21 if I remember correctly and I think -41VDC on R20...it shows 35V on the schematic so this seems quite high
what could be the problem?
showing 1 stamped on the revision? I think the schematic is Rev2
heres what i found
