Making a simple beep circuit!
steve10
Joined Apr 28, 2008
2
I am using this as a template: http://www.allaboutcircuits.com/vol_6/chpt_5/18.html
I am trying to make a simple circuit, that beeps (like a beep from a microwave oven.) I am correct using this circuit, and replacing the audio detector with a button.( to make the desired beep )
Also Replacing the led light with a speaker.
Please let me know if this sounds correct.
Thanks, Steve
Audioguru
Joined Dec 20, 2007
11,248
A speaker draws a high current. The circuit is designed to drive an LED with a low current.
Why not replace the entire circuit with a piezo beeper that has its own built-in oscillator. Apply a supply voltage from 3V to 12V at low current and it beeps.
Wendy
Joined Mar 24, 2008
23,421
Do you want a simple beep with a button press? This circuit was meant to give you probe to show it switching, which was the purpose of the LED/transistor. There are literally hundreds (thousands?) of ways to do this. Ham radio types like to do something similar to practice morse with a key, for example.
Is it the fact the breadboard is spelled out so completely or what? Or are you curious about the circuit itself?
I ask this not to criticize, but so I can help. Guru is right, you can buy sonalerts and other piezeo oscillators premade, although I personally hate their pitch (a lot, way too high for my tastes).
The experiment page is a good place to start, it focuses you towards a definate design. A slight modification of the circuit will drive the speaker by itself, if that is what you want. When it comes to audio oscillators I tend towards the 555 or 556 integrated circuits though, a lot fewer parts and more predictable, not to mention cheap,
steve10
Joined Apr 28, 2008
2
Thank you, for the reply.
Yes. I am looking to produce a device, that will make the desired sound. The more basic, and simple that it is, the better. I do not care what it is made from, as long as it is small.
Again, the desired sound that I am looking for, is much like the sound, that comes from a microwave touch pad.
I want to just loop it through a push button, to crate the quick beep tone. This is just for recreational purposes.
Thanks again,
Steve
Wendy
Joined Mar 24, 2008
23,421
Here are some other ways of doing it. If you still want to built the classic astable you pointed out let me know. The pots maximum value sets the low frequency, you should be able to adjust it to whatever note you want. Use the power supply for the 1st circuit to turn it on/off, the third schematic shows a way of digitally turning the oscillator on/off, as well as a major power boost if the first circuit is too quiet, while the second circuit shows a more conservitive way of boosting power (you will need a power transistor and a possibly a heatsink). 555 ICs are not meant for high power, but they are cheap and available almost anywhere parts are sold. You could even experiment and eliminate the 100 uF capacitor on the 1st circuit, if the speaker can take the DC then it will work OK.
The values are not critical. A 100K 10 turn pot and a .1uF cap for R and C will give you a minimum frequency of 70 hertz, which isn't quite sub audio but close. The capacitor on pin 5 isn't necessary, but will prevent glitches for more precision applications. If the battery is far away then you might want to put a filter cap on the power supply. The basic circuit is also very forgiving on the power supply voltages (5-15V), a 9 volt battery will work well.
Like I said earlier, there are lots of ways of doing this, transistors are a good beginning.
zx16v
Joined Oct 13, 2009
2
hello,i dont know much in electronics..but i mange to build a 555 circuit with buzzer that makes beep beep beep sound,this is nice...but what i need is that when the circuit will get 12v it will make ONLY 3 beeps and stop untill the next time the circuit will get 12v.
the idea is to connect the circuit to my shift light in car and when the light is ON it will be turn ON the cirucit but ONLY for 3 beeps no metter if the light is still ON.
can i add only some kind of relay for that or if someone have any simple diagram for that it will be great.
please advice
many thanks
Guy
Wendy
Joined Mar 24, 2008
23,421
Again, simple enough to do. But first a side note, you're much better off starting your own thread, tacking on to someone else thread is called hijacking, and is discouraged.
Just put a monostable on the beeper, set the duration for whatever it take to let 3 beeps out.
555 Monostable
Connect this circuit to pin 4 of your existing 555 (disconnecting it from the power).
Adjust R4 for your 3 beeps.
zx16v
Joined Oct 13, 2009
2
thank you for your fast replay
the diagram you post is the one im looking for? 3 beeps and stops even the battery is still connected to the circuit?
and sorry for posting here,if you want i will open a new thread.thanks!
Wendy
Joined Mar 24, 2008
23,421
If a mod objects he'll take care of it.
Basically, from the information you gave, the above circuit will modify it to do what you want. Post your schematic and I'll link them.
Bernard
Joined Aug 7, 2008
5,784
zx16v, for 3 beeps, might use a 556 & 4022, first section for clock, second for beep osc. Use out 2,4 & 6 to gate beep osc. ,3,& 5 spacers. Prob need another chip to control turn-on. Maybe someone will connect the dots.
