KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
I can think of a few methods to measure current: The current transformer (AC only); Hall effect; High side sense; low side sense; there is a new method I read about *Magnetic"I do not really need too much isolation and I can just use an op-amp. And given that it only adds a few milliohms, I think it is the better choice. Plus with such large currents there may be other magnetic fields that would give inaccurate readings. And would it really be that accurate? I am just pretty skeptical.
You have to pick one. A high side monitor will require some effort, so it makes sense to buy. See: https://www.maximintegrated.com/en/app-notes/index.mvp/id/746 I'm not advocating any part. Sometimes you don;t have much of a choice with full scale voltage.
High current connections are usually done with "bus bars". On the 45 A power supplies I bought, two copper rectangular bars with threaded holes were where you attached your wires.
Some high current lugs are here: https://www.platt.com/platt-electri...+ground+lug§ionid=4&groupid=61&CatID=1254
Connections to welding cables are normally to a lug where the wire is secured with a screw. For stranded cable, usually some sort of plate (wire guard) is pushed against the stranded wire. You do need to look at suitability.
Some connections, like crimp are not suitable for solid wire. Crimp lugs for very large diameter cables might require a hydraulic crimper.
One work gizmo needed 6V AC at 3000 Amps (yes three thousand). The connection to the transformer was a bar probably about 8" wide x 3/8" thick.
A wire chart is here: https://www.powerstream.com/Wire_Size.htm
I used 8 AWG for transmission about 6 feet maximum in my application in the 40-45 A range.
The soldering isn't the big deal. It's the flux vapors. Solder typically isn't used with high current connections.
Silver plated tubing is actually used. Silver soldering or brazing is a very solid connection. When you actually get really picky about solder and accuracy, every solder joint is a thermocouple. Those effects are usually neglected.
I think that covers about 1/2 of post #58.
