Hi. I want to say at the outset that I searched both Google and the forums here like crazy and couldn't find an answer that quite fit my situation. Or if I did, I couldn't translate it to my project. Pretty sure what I'm looking for isn't difficult for people who know even a little more than I do (almost nothing) about electronics. So here goes.
I have a book nook kit that is supposed to look like a firefly garden. It came with the items in the first photo. 2 of the strings of lights have 5 lights, the last one has 6, and then there's a single one. The way you're supposed to assemble all this is to take all the grey wires from all the lights (including the single LED), and connect them to the grey wire on the circuit board, then take all the white wires from the lights and connect them to the white wire on the circuit board. I understand this.
![IMG_20240228_170706557.jpg IMG_20240228_170706557.jpg](https://forum.allaboutcircuits.com/data/attachments/304/304098-f162cf7255226d7a43e75b7215aac07d.jpg)
The single light will be stuck through a hole on the bottom of a panel. The rest of the lights will be stuck through holes further up on the panel. The wires come out the back, with the battery circuit board and switch mounted inside the nook. As in this diagram (I didn't bother drawing all the lines representing the wires).
![Firefly-Garden-Layout.jpg Firefly-Garden-Layout.jpg](https://forum.allaboutcircuits.com/data/attachments/304/304099-8de713611fa261a83d50cab38b3497d6.jpg)
But I don't want to use their lights, they just light up and don't do anything. I want lights that actually pulse on and off like a firefly. I've searched and searched, and can't find any LEDs that blink on, then blink off randomly, only strings that ALL of them flash off and on at the same time. So the closest I can find are ones that flicker such as these. Still not ideal, but better than anything else I've found (unless someone can point me towards something that does what I'm after). So what I'm thinking I need is 16 of the 3mm flicker LED's from the link, a power source, and a switch. My problem is, I don't know what to use as a power source because I am not knowledgeable enough to figure out what it'd need in battery power. Also, I don't know the best way to wire it all together. Do I connect all of the lights individually to a connection on the power source with the switch in the appropriate place (I'm assuming between the positive connection on the power source to the positive wire of the lights), or do I connect the led's to each other in a chain, with the resulting start and end wires hooked up to the power source appropriately (including the switch).
I much appreciate any help I can get here. The closest I've come to this is wiring a motor to a wooden automaton that's supposed to be hand cranked. So no real experience with lighting. Thanks!
