Hi, I tried to construct a subcircuit model of an ideal Operational Transconductance Amplifier (OTA). It's nothing more than a voltage-controlled current source but it doesn't work correctly in some circuits.
Here is the circuit equivalent and the netlist of the OTA:
And here is the circuit I try to simulate. Op-Amp works correctly as a comparator. The OTA and capacitor should've act as an integrator but no. (Resistor in the end is just for the output node not to be floating since output is current, Vout = Io*1)
The output should be a triangle wave right? Since (square wave) -> (integrator) -> (triangle wave)
When I use a behavioral voltage source as an equivalent of the OTA integrator it works fine. What is the problem with the subcircuit?
