I know this is possible, I've been advised on it before. The grey matter isn't what it once was though and if you don't use something for a while things get embarrassing. This time I'll have to tattoo it in an obvious place.
If you generate a family of curves dependent on a ".step param" type command, how do you restrict your display pane to one particular curve for a single value in the family? This should be something like right clicking on the pane title and then editing the displayed node to add the number from the family, it would look something like V(vout)#3, but I can't get the format correct.
Is it even possible to select a few of them at a time from the family?
