LTSpice Boost Converter Simulation and Improvement
artmaster547
Joined Jan 6, 2016
409
Hi All I have setup a simulation in LTSpice with components selected that I wish to create a real PCB for but wanted to simulate it first.
I am having a it of an issue with the design I used LTpowerCAD initially to workout what components to use, It takes in 12V and outputs 40V @ 7.5A. However when simulating it does not produce the output waveform expected I feel like I am missing something trivial any help would be appreciated. Simulation is attached with this post. Any suggestions for improvements or reduction of any noise would also be appreciated.
Kind Regards
Art
wayneh
Joined Sep 9, 2010
18,106
Are you trying to mimic the "Typical Application" on the data sheet? I saw at least one difference in your schematic versus that (the PLLIN is grounded in the data sheet version).
I confirm that your simulation produces ~11.6V at the output, not 40V.
artmaster547
Joined Jan 6, 2016
409
Hi yes realised I made that mistake and ammended it the output is not quite as good as I would like, I wanted to see if I could get it to function under continuous conduction mode.
ericgibbs
Joined Jan 29, 2010
21,443
hi 547,
This is your circuit using good quality low ESR commercial capacitors on the Out and Inp Voltages
E
EDIT:
For comparison your original circuit is shown in A002 image.
artmaster547
Joined Jan 6, 2016
409
hi 547,
E
would you mind posting up the improved LTSpice file, also any recommendations for which capacitors? The capacitors have been my main concern especially finding suitable ceramic ones because of their lower ESR values and suggestions would be warmly welcome.
