LTS Analysis of RLC circuit and Testing w/o GND loop
29,976
Capacitance measured with Vici VC8145 bench meter (also inductor R) and inductor with a GM328 Multi-use Transistor Tester for inductance. On my SZJB BM4070 LCR meter, I get 30.7mH & 76.1Ω for the inductor and 8.3nF on the cap. So the values are very close for both instruments. I can only assume from the calculation results that there might be some error for cap and inductor but the big error is for the resistor? Which measures at less than 1% error than the ideal 1kΩ marked. I could have swapped the resistor but swapping out the cap seemed to resovle measuring Vpp across it with the Oscope.
When you say that the big error is for the resistor, is that when you are using the nominal values for all of the components, or the measured values for them?
SamR
Joined Mar 19, 2019
5,031
For Vr
Nominal: 5.78V
Actual: 4.61V
Meas: 3.76V
Small difference but a large error.
Edit: now that I stop and think about it any small error in L or C gets magnified in the Z calculation used to determine current. But then it is also used to calculate the V for L and C so it becomes a circular argument? No because of the magnitude of V for L and C it would be a smaller error than for Vr?
Jony130
Joined Feb 17, 2009
5,487
Try AC analysis for a single frequency
Code:
.ac oct 1 6k 6k
But do not forget that the components in the simulation have a "polarity".
Jony130
Joined Feb 17, 2009
5,487
I have an off-topic question.
Why you (Americans) you don't like to use nF ?
Why 0.o1μF instead 10nF ?
SamR
Joined Mar 19, 2019
5,031
No particular reason although some vendors don't list components in nF or mH instead listing as 100'000uH and .001uF. I would actually prefer mH and nF. Back to LTS is there a way to print the AC Analysis directly from LTS? I've snipping and printing a screenshot to get it.
29,976
For Vr
Nominal: 5.78V
Actual: 4.61V
Meas: 3.76V
But
My guess is that it is just tradition. Since capacitances span such a huge range of values, limiting the units used arguably makes it easier for people to more quickly grasp relative sizes. So you express all but the smallest (pF-scale) and largest (F-scale) values with a single unit (uF) for everything from 0.001 uF to 470,000 uF.
I personally prefer using engineering prefix convention on most things unless there's a specific reason not to.
SamR
Joined Mar 19, 2019
5,031
Been thinking about why I adopted the .u notation. As I said I actually prefer to use n. Most of the books/texts that I have worked with use the .u notation and that was what was used in the lab manual for this exercise and I blindly used it when I copied the circuit into LTS. Fell into a bad habit? Strange because the books use mH and most vendors use uH instead? No solid sense of conformity here. I don't think I have ever seen a nano-sized cap used for anything but the capacitive grounding of ac or a pico-sized used for anything.
34,280
And going back a ways, we didn't even use pF; we used μμF instead. And we spoke of "cycles per second" instead of "Hz."
Yes, I also remember well those days of μμF capacitors and kc frequencies (c was often incorrectly used for cps).
Another oldie.
29,976
Habit/tradition. Nothing more than that. And going back a ways, we didn't even use pF; we used μμF instead. And we spoke of "cycles per second" instead of "Hz."
I feel old.
And since typewriters didn't have a 'μ' symbol a 'u' was (and still is) commonly used, but another alternative was to write μF as mmF. I gave a teacher some grief (because he came up in the trades when mmF and uuF were very common) and so on a test I gave an answer in mmmmF instead of pF. When it was marked down (partially), I objected arguing that if it was acceptable to use mmF (in direct violation of the S.I. guidelines), then mmmmF had to be considered acceptable, too. He gave me the points back on the condition that I agree not to pull that crap any further.
MMF was not an abbreviation for microfarad, which it might have been if the M was an abbreviation for milli-.
MMF (sometimes MMFD) was an abbreviation for micromicrofarad.
At the bottom of this page: http://www.radioremembered.org/capcode.htm we find the following little chart:
Here is a picture of an old mica capacitor with the value 47 MMF printed on it:
Just to make sure it's not a 47 millimillifarad capacitor, I measured it on an LCR meter:
It really is a 47 (nominal) pF capacitor--MMF stood for micromicrofarad in the old days.
29,976
Yep, I believe you are correct. I was misremembering it (it's been decades since I've seen that).
