1st the experiment for the following circuit is to measure Vpp across each component but there is a caveat in the instructions. "Avoid ground loops by moving resistor and inductor to keep the same ground point." I assume the resistor is in the correct place to measure and to measure the inductor they need to swap places in the circuit so when measured they will have the same relative ground point beside the capacitor?
2nd I would like to also do this in Spice. I have selected a "signal" and defined it for 10(volts) 6k(Hz) and AC sweeping to 6k(Hz) over an Octave? Or do a transient analysis?
