Hello , I am using LT1028 in simulation from the datasheet shown below
Pin 1 and 8 are Vos TRIM
Pin 5 is OVER-COMP
regarding Vos:
Vos is input offset voltage-
In my LTSPICE simulate i didnt have in the model i only had input output and zero
The input offset voltage (VOS) is defined as the voltage that must be applied between the two input terminals of the op amp to obtain zero volts at the output.
by the data sheet bellow, how do i know what value should i use?
Thanks.
https://www.digikey.co.il/en/products/detail/analog-devices-inc/LT1028CS8-TRPBF/959596
https://www.snapeda.com/parts/LT102...Analog Devices/view-part/?ref=search&t=LT1028
https://www.analog.com/media/en/technical-documentation/data-sheets/1028fd.pdf
Pin 5 is OVER-COMP
regarding Vos:
Thanks.
