LP filter transfer function + Matlab Plot
Shagas
Joined May 13, 2013
804
Hello ,
Could someone help me out plotting a Bode and nyquist diagram in matlab
of a simple R/c low pass filter?
I'm making a presentation of my semestral work in a few weeks of a very basic oscilloscope that I made in java and a small part of the presentation is the input analog ciruitry.
So first I have to find the transfer function. I've looked on this page and it says that the transfer function will be
1/(jwRC + 1)
I understand how they derived that but I don't understand what the j and w will be. Do I consider w as 2pi/T - (2*pi*F) ? What about the j , and how would I plot this function in matlab?
Also , I have two r/c stages for a steeper low pass but If I remember from the signals course lecture I can just multiply the two transfer functions that are in the S domain to get the total transfer function.
(I know that two cascaded R/C stages aren't optimal and that I should put a buffer in between but for simplicity sake I just cascaded them without a buffer)
Thanks in advance
ericgibbs
Joined Jan 29, 2010
18,865
hi,
I dont use Matlab, but these are the two questions you asked.
In this context the 'j' indicates advance the phase by 90 degrees.
The 'w' = 2 * pi * f
E
Shagas
Joined May 13, 2013
804
Ok thanks for the answer ,
I will wait for someone who can advise how to punch that in to matlab
Veracohr
Joined Jan 3, 2011
772
For the Bode plot you can use the filter coefficients and the freqz function (it also creates a phase plot), but it would be easiest to just create an array for frequencies and plot the magnitude of the transfer function against that array.
I have no experience with Nyzquist diagrams.
