Art I know you are trying to help but at this juncture I'm just trying to get the TS to figure out if the switches involved are wired NO or NC.Still missing are the two connections to power.
I would appreciate if you didn't respond at this time.
Ah! Well therein lies the source of my confusion, it would seem. Apologies for misunderstanding earlier, and thanks for your patience.That's were your problem is. You don't branch off the pads you have to connect into the wiring which I'm trying to explain in the post above.
Both switches open:Just need to measure on the pins in the connector that I labeled 1-4
measure across 1and 2 then across 3 and 4 and see what you get.
Great that's all you need to know.So based on this, it looks like the Up switch is wired NC, and the Down switch is wired NO?
Okay! Based on what you've said here, I've mocked up a diagram that looks like maybe a second-grader was involved, but it gets the point across I think. Can you confirm my understanding is correct before I go connecting everything up? It makes sense to me but another set of eyes would be great!Great that's all you need to know.
Wire the Down relay across the two wires coming off pins 3 and 4 using the C and NO contacts.
The Up relay C and NC contacts must be wire in series with the Up switch.
You do that by cutting either wire on pins 1 and 2 and connect one end to C and the other to NC on the relay.
Still missing are the two connections to power. Since this has a DC power source, that requires the power's polarity to be reversed to change the (DC) motor's direction. This is normally done with a cross-connected DPDT center-off momentary switch. For more details, see: https://forum.digikey.com/t/polarity-reversal-using-a-dpdt-switch/626
The case that you have using 2 momentary SPST microswitches should be as shown here: https://electronics.stackexchange.c...otor-with-2-microswitches-reversing-direction
by Aaron Carman
by Aaron Carman
by Aaron Carman
by Jake Hertz
