I am looking for Industrial Grade Wireless Digital-to-Analog Converters (DACs).
These DACs should be capable of receiving and accepting wireless digital transmission from industrial grade wireless vibration sensors, convert it into its corresponding analog/voltage signal, and send this signal out through analog/voltage output channels. The analog/voltage signal should be in 0 to ±10V (i.e. both AC and DC voltage).
I am primarily looking for 3 basic configurations:
1. 4-Channel - the DAC should be able to receive data simultaneously from 4 wireless vibration sensors with 1-axis measurement (or 1 tri-axial wireless accelerometer and 1 uniaxial accelerometers) and should be able to convert them into 4 corresponding analog/voltage outputs.
2. 8-Channel - the DAC should be able to receive data simultaneously from 2 wireless vibration sensors with 1-axis measurement (or 2 tri-axial wireless accelerometers and 2 uniaxial accelerometers) and should be able to convert them into 8 corresponding analog/voltage outputs.
3. 16-Channel - the DAC should be able to receive data simultaneously from 16 wireless vibration sensors with 1-axis measurement (or 5 tri-axial wireless accelerometers and 1 uniaxial accelerometer) and should be able to convert them into 16 corresponding analog/voltage outputs.
I am also open to purchase a combination of sensor + DAC both in case if sensor independent DAC is not available.
Any help or pointer in right direction will be greatly appreciated.
Many Thanks,
Many Thanks,
