Looking for a device that would sense input voltage and would have four seprate outputs to control high voltage contactors
JazzK
Joined Jan 23, 2020
Hi, I am looking for a device that can handle at least minimum 140 volts and on high side at least minimum 300 volts, 2 phase and would have four separate outputs on which I want to connect four separate contactors and they would be connected to a multi volt transformer which would be handling the load. So for example if I have 190 volts coming in the device would energize output 1 and that would energize contactor 1 which would be connected to 190 volts transformer that would step up the voltage back to 240Volts. Any suggestions.
