In many power supplies, auxiliary outputs are post-regulated with the classic 3 terminal regulators to eliminate ripple and / or get better regulation. That's what we're doing in our product, where we need a low power +/- 24V power rail for closed loop hall effect current sensors. They have a pretty tight specification for the power rails, so we use a pair of LM7824 / LM7924 3 terminal regulators to post regulate a flyback power supply output.
We have now been notified that the LM7924 is sole source and possibly that one source is at risk of obsolescence.
I can think of multiple options that would use alternative parts, but everything in the classic linear regulator family is around 45 years old, so I wonder if there is any indication of what route is least likely to disappear too. My options I've considered are:
Anyone have some insight into what is most likely to be viable in the long term?
- Use a floating winding for the negative rail and use LM7824 regulators for both negative and positive
- Use LM317 / LM337 adjustable regulators
- Use LM7815/LM7915 or LM7812/LM7912 with elevated output voltage by raising the ground terminal (Some risk as some brands have lower in / out limits so the number of devices is lower)
- The above two options but only using the positive devices and floating the negative winding.
- Using something more modern, either a newer linear or go non-isolated switching regulator.
