Mod edit: thread title changed by member request from:
Long Delays with the 555 Timer or Alternate IC
JohnInTX
....but not a uC! I am dead-in-the-water with respect to uC's.
The entire project will be a Sequential Float Charger circuit using a single Float charger. I am looking to control the rotation of a half dozen Lead-Acid Batteries. My plan is to use a timer that will produce a charge time of 10, 20, or 40 minutes before switching to the next battery. My current dilemma is getting a somewhat stable time period out of the 555 timer. The circuit below is the general idea.
Not only am I looking for the ON times of 10min, 20minm 40min, but I am looking for the 1sec OFF time to advance the CD4017 to connect the next battery. The times for the 555 are not needing to be super accurate, within a minute or two. So far, though, The times have been inconsistent when using three 220uF Low ESR Caps in parallel. I looked at a 330uF Ceramic cap and almost ____ my pants, $22.
For the 10min Timer, I'd like to stay +/- 30sec, for the 20Min timer maybe +/- 1min, and for the 40min timer, +/- 2min. It really stinks to sit waiting 20/40min to see how close I am. And YES a uC would be great, but I want the project done long before I learn the language well enough to make this happen.
I have a few ICM7242IPA PDIP-8 Timers that would enable me to easily get accurate timing, but the chip does not seem to be able to alter the duty cycle so that I can increment the CD4017. DATASHEET
Help & Suggestions needed!
Thanks ALL!
JohnInTX
Thanks ALL!
