note : 5 channel flame sensor is used which is mounted on the end effector of the arm,and the robotic arm scan does 180 degree scanning...So experts you are all in here..
hey listen m also using PCA9685 Servo motor driver to control the robotic arm ,,,i just only need the help in following / tracking of the flame once its get detected ??????
Code:
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
#define FLAME_SENSOR_PIN A0
#define FIRE_THRESHOLD 200
#define MIN_ANGLE 0
#define MAX_ANGLE 180
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
int servoPin = 0;
void setup() {
Serial.begin(9600);
pwm.begin();
pwm.setPWMFreq(60);
void loop() {
for (int angle = MIN_ANGLE; angle <= MAX_ANGLE; angle++) {
pwm.setPWM(servoPin, 0, map(angle, 0, 180, 120, 620));
int flameValue = analogRead(FLAME_SENSOR_PIN);
if (flameValue > FIRE_THRESHOLD) {
Serial.println("Fire detected!");
break;
delay(20);
