LM7824 Only 52mA but Hot??
R!f@@
Joined Apr 2, 2009
9,918
Ah ! tht's ur problem.
U need caps across them too.
And u need a varistor across the primary of the transformer plus a 0.1uf 250V capacitor
Those will suppress the spike from getting into the transformer
R!f@@
Joined Apr 2, 2009
9,918
I had it wrong.
Either way it's better to use 275V Varistor if the mains is 220VAC and 175VAC on a 110VAC line.
The spikes are back emf from the solenoids connected across the 24VAC tap.
There are two ways to stop it. Use a second transformer to power them
Other way is to Varistor across the secondary.
U have 24VAC at the secondary. so a 30V one will suite u, but I don't think u can get that low value.
I dunno if this method will work, but it's worth a try.
Find two 27V to 33V 1W zener diodes and connect them back to back across the secondary of the transformer
{ed}
I changed the zener value after thinking for a while.
15V will short circuit the 24VAC
tigerapna
Joined Dec 14, 2011
73
I had it wrong.
What power rating of MOV? I found 30VAC MOV's on digikey.
My inductive loads are 8Watts each. And 4-5 will be connected to the transformer secondary. (not all on at once)
R!f@@
Joined Apr 2, 2009
9,918
Really ! 30V MOV's ?
Get 'em and connect one across the secondary.
As for power rating, does not matter much. Get one that satisfies u or is there any professor here who can calculate the back EMF generated by the OP's solenoids, so OP can find the energy value that he needs for the MOV.
D General Electronics Chat 4
Similar threads
LM7824 OrCAS PSpice model
