hi ep,I have connected PIC controller on the output side of the regulator
TI's datasheet says 220nF on the input pin (though I also use 100nF), but nothing on the output pin. I prefer a 10uF aluminium electrolytic on the output, as it acts like a zobel network due to its large ESR. I think it was something recommended by Bob Pease.Definitely there must also be a bypass capacitor at the input to that regulator. I had a similar experience and it was oscillating at several megahertz. The fix was adding the input bypass close to the regulator. Just like the app note states. 0.1 mfd within 1/2 inch. consult the application notes for their suggestion of how close.
Hi Martin, do you have a source for that? I made a lab supply with LM7808, LM7908, LM317 and LM337. The LM7908 starts to regulate correctly around ~3mA. I cannot find this requirement in the datasheet or online.These regulators need a load of at least 5mA to stabilise properly. Try loading it with 1K and measure the voltage.
TI does not specify a minimum load.Hi Martin, do you have a source for that? I made a lab supply with LM7808, LM7908, LM317 and LM337. The LM7908 starts to regulate correctly around ~3mA. I cannot find this requirement in the datasheet or online.
NO, that is not a minimum load current, that is the load current range for which the device is guaranteed to meet the voltage output specification. Spec sheets can indeed be confusing sometimes.LM7805 lists the minimum current here:
Wow, I totally missed that.LM7805 lists the minimum current here:
How is that different? I mean, it would be the minimum load current required for the device to operate properly wouldn't it?NO, that is not a minimum load current, that is the load current range for which the device is guaranteed to meet the voltage output specification. Spec sheets can indeed be confusing sometimes.
by Aaron Carman
by Jake Hertz
by Duane Benson
