LM78*** Voltage regulator spice model
Anotida Mushayavanhu
Joined Nov 22, 2020
24
Hello guys ..I have used an LM7805 voltage regulator in my project . However when i try to simulate I am getting an error " couldn't open library file "LM7805 _7812_7815.lib" so I guess I need spice models for the regulators to add to the DIO file ..May yu kindly send if you have them .Thank you
Alec_t
Joined Sep 17, 2013
14,335
Regulators are not diodes, so don't belong in the DIO file.
A common reason for the error message is that your model file is in the wrong place.
What version of LTS are you using? What OS?
Have you downloaded and saved that lib file?
Joined Nov 22, 2020
24
LTSPICE XVII
I don't know where to download there lib file and where to put it .Maybe you can help
Alec_t
Joined Sep 17, 2013
14,335
If your OS is Win10 then by default the lib file goes in your User/Documents/LTspiceXV11/lib/sub folder and the asy symbol files go in User/Documents/LTspiceXV11/lib/asy folder.
