Hi Guys, so I made a circuit a while ago, it's a 30 step (LED) analog temp sensor/display. I'm using a LM35 for the sensor, and 3x LM3914's for the display. now the standard bar mode works perfectly fine, shows the full range of 0-150 deg if I put a heat gun on the sensor so all good there. I want to add to it a bit before I put it in the car. I want it to flash when the temp is over a set range. now I've done pretty close to the circuit in the LM3914 datasheet (page 13), with the 100 ohm res on the cathode of a lower LED and the junction between R1 and C1 connected to the cathode of the same LED. now the value of the 1.2k and 470Ω resistors in the diagram are different on my breadboard mainly because it's just what I had on hand but it works so I don't think this is where any issues lie.
3 things I'm having issues with or would like clarification.
1. I've increased the size of C1 to 1000μF to decrease the speed that graph flashes. I assumed it was the cap that controls this and hey I was right there . problem is though that the speed varies and is quite noticeable. any way to overcome this? or should I just design a better circuit that controls the flash from the anode side of the LED's?
2. the diagram shows the 470Ω resistor going back to ref out. I assume I would need to do this for each LM3914 to get them all flashing? atm it's only the 3rd set of LED's that flash because it's only that one that's connected.
3. I will be running a PWM circuit (already designed and built) to control the brightness of the LED's, will this interfere with the flasher component? or should I just tag something on the side of the PWM that controls the flash. I'm starting to think this might be a better option.
I've probably rambled on enough, thanks in advance for any help guys.
