Excelent, thank you.Add a voltage divider to pin 4.
SGView attachment 215132
Correct, the schematic that the TS posted cannot be accurate. He shows pins 6,7 and 8 grounded, there would be no reference voltage for the comparators. Right?Your circuit might be destroying the LM3914 because you are shorting its pin 7 reference voltage OUTPUT to ground.
That's right. With pin 6 at 0V then the comparators do not work properly.Correct, the schematic that the TS posted cannot be accurate. He shows pins 6,7 and 8 grounded, there would be no reference voltage for the comparators. Right?
SG
A voltage divider is better than the diodes. The diodes have temperature stability problems. But it was a fast way to try something.Add a voltage divider to pin 4.
Indeed they were barely open all the time. You have to get over them perpendicularly to see them lit. From an angle they are almost visible. I dim them like that for testing purposes, for non-interfearence, but mostly because they were attacking my eyes and see dark spots. So i dim the life out of them to be able to work and just see the effects they make. When I will put them on the final circuit, I will put a lighter resistence, just to leave them at their peak intensity, or... depends on the further tests, how good they will look. Its not always necessary to be at full brightness. A good designer will balance and use its eye to feel what is good. But thanks for that math you did there, it's always good to know. I will play with the regulator on pin 7 also.Very very dim.
