The LM317 needs about 1.7 - 1.8V (3V guaranteed). Add 1.25V for the current set resistor, 9V for the LEDs, and your minimum supply voltage is 12V. This doesn't mean you won't get current, but it does mean the current may drop slightly when the supply is below 12V. It may not be objectionable.Each led takes 1.8 volts so 5*1.8=9v the lowest the supply voltage gets is about 11.3v so with the 1.25v that would be 10.05v left for the leds and stuff. So I am good to go on the circuit in regard to enough voltage. Thanks
