Remember, sgtwookie suggested the LM317L which is in a different package. You probably need to access the data sheet for the LM317T which will show the pinouts for the TO-220 package.Vin should be pin 1, ADJ should be pin 2, and Vout should be pin 3. That's what it appears to be on the data sheet that sgtwookie supplied on the first page of this thread. Someone want to confirm this?
Thread starter | Similar threads | Forum | Replies | Date |
J | LM317 current injector/boosting circuit | Analog & Mixed-Signal Design | 28 | |
K | Mounting LM317 TO-3 case | Power Electronics | 13 | |
L | LM317 no reference voltage | Power Electronics | 20 | |
LM317 Adjustable Voltage Regulator project | General Electronics Chat | 17 | ||
K | Lm317 high current voltage regulator circuit | General Electronics Chat | 28 |
by Duane Benson
by Aaron Carman
by Duane Benson
