thatoneguy
- Joined Feb 19, 2009
- 6,359
What is the application for the op amp?
There are many op amps similar to what you've listed in higher end audio applications. The only place absolute flat linearity with no phase shift would be needed is typically an instrumentation device, and even then, the op amps listed are flat response when used in properly designed circuit.
If the purpose is for a "perfectly flat" audio amplifier, there will be far greater problems finding a BJT or MOSFET that comes close to the range and response of many op amps.
