A bench power supply 30v etc should get some movement out of those motors.Apparently he is going to have to order a new control board. He brought three to me: one was incompatible and the other two had burned resistors. He wanted me to just replace the resistors, which I did. He has installed both boards and the motors don't run.
A new control board is about $400, and before he buys a new one and maybe fries it, we need to test the motors. They are marked 90VDC, .63A, 1/15 HP. Where would I come up with a power source to confirm that the motors will run?
Sorry if that came out wrong Max! I know this is your area of expertise and was just commenting on the appearance of the circuit based on that one photo. A check of the part numbers on the two power devices will show if they are SCR (phase angle control) or IGBT (PWM).Maxheadroom said:I realize how an SCR bridge works, it is just very unusual to see such a large cap on SCR drive, these are more common on the PWM versions. ...
I was unable to find a datasheet for the A69104 SCRs, but recent production of the boards still shows them in use.It does appear by the part number that they are sensitive gate SCR's made by Teccor which are no longer, as they were taken over by LittleFuse.
Max.
If there seems like a common source of failure, maybe there is a bit of a design flaw?Apparently he is going to have to order a new control board. He brought three to me: two had burned resistors. He wanted me to just replace the resistors, which I did.
Thanks.
by Aaron Carman
by Jake Hertz
