Lighting a Ghost costume, Need suggestions
Coopette
Joined Sep 21, 2012
4
I am making a Starcraft Sarah Kerrigan Ghost costume which lights up. When I get it finished I can post a picture if you guys help. If you want to see a video of the costume I am trying to recreate see below.
http://www.youtube.com/watch?v=SG_3R9BoVvg
I need help finding the best way to do this. I know there are a couple of options like EL wire or LEDs. I think LED would be better, thus I am looking to recreate a chasing effect using LED light strips. I know there are alot of premade kits that can do over 80 different effects but I only need one simple light "traveling" through the strip. Like in the video below at 1:00 minute but only a single color.
http://www.youtube.com/watch?v=2zSkkaif4Kk
As another option could I be able to change it from one single color to a different color keeping the same chasing pattern. This is why I am considereing RGB lights instead of regular LEDs but I want this to be as affordable as possible.
If you have any suggestions or ideas please let me know. I appreaciate all help.
Thanks in advance
Markd77
Joined Sep 7, 2009
2,806
Coopette
Joined Sep 21, 2012
4
Is there any way to make the circuit light weight and portable? with all the wires it looks really messy and I only have about a square 4 inches to hide the circuit
ScottWang
Joined Aug 23, 2012
7,409
I am looking to recreat a chasing effect using LED light strips. I know there are alot of premade kits that can do over 80 different effects but I only need one simple light "traveling" through the strip. Like in the video below at 1:00 minute but only a single color.
Thanks in advance. :)
If you like to do so, can you write the program for MCU as 8051 or PIC, etc...?
Or you want to use NE555 + CD4017x3 (or x 5) + Some RC to try it.
Or NE555 + Ctrl Logic +CD4510x3 (or x5) + CD4028 x3 (or x5) + Some RC to try it.
Or NE555 + Ctrl Logic +CD4516x3 (or x5) + 74LS154 x3 (or x5) + Some RC to try it.
CD4017 datasheet, Decade Counter/Divider with 10 Decoded Outputs
http://www.datasheetcatalog.org/datasheets/90/108738_DS.pdf
CD4510(BCD)/CD4516(Binary) datasheet, Up/Down counter.
http://www.datasheetcatalog.org/datasheets/320/109577_DS.pdf
74LS154 datasheet, 4 to 16 decoder, Output Lo.
http://www.datasheetcatalog.org/datasheets/70/232348_DS.pdf
CD4028 datasheet, BCD to 10 decoder, Output Hi.
http://www.datasheetcatalog.org/datasheets/228/108936_DS.pdf
BSomer
Joined Dec 28, 2011
434
Another alternative to the conventional wiring methods would be something referred to as e-textiles. There are many different possibilities with this stuff. Micro-controllers, LEDs, batteries, whatever...
