Hai every one,
I have been working under varying the brightness of the ac loads using the triac and a microcontroller.
I have written code for it and I tried for the output on the simulator as we cannot see the dimming on the simulator I have seen the output voltage which is varying for different levels but practically I am not getting the output which I am getting on the simulator
Here is the schematics I have done......
AT THE BOTTOM OF THE FORUM........
and the code I have written is........
Concept:
The concept I have used is that if I want a less brightness the I will increase the delay time for the triac to trigger where we are increasing the delay angle and decrease the conduction there by decreasing the rms output so like wise I for example if I want 20% brightness I will give zero pulse for 8 ms and will give high pulse for 100us(0.1 ms) and then off for the remaining time like wise I have divided into 16 levels where the input I give from the switches(based on the basic concept of the TRIAC) which you can see on the above code
Problems:
The problems I am facing in the hardware are the
1.In the schematic I am grounding the ac neutral and the T1 of the triac to the circuit ground so if I do that on the bread board the lamp is lighting at only one level and the 220 ohm resistor is burning
2.If I don't do the grounding like that the lamp is not at lighting on
I am unable to know where the problem persist
1.whether am I going wrong in detecting zero or
2.producing pwm which indeed depend on the zero crossing
Queries:
1. I don't have the CRO so how to check whether my zerocrossing detector is producing the zero crossing or not
2. And how to check whether my microcontroller is producing the desired pwm wave or not
Any help is very much valuable for me.......
Thanks in advance
Rich (BB code):
org 00h
MOV P2,#00H
MOV P1,#00H
MOV TMOD,#01H
MOV SCON,#50H
MAIN:
MOV A,P1;// to take data from the switches into the accumulator
LOOP1:
CJNE A,#01H,LOOP2
S1:JNB P2.1,S1
SETB P2.0
MOV TL0,#0A4H//0.1MSEC ON
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TL0,#3DH//9.1MSEC OFF
MOV TH0,#0DFH
CALL DELAY
LJMP MAIN
LOOP2:
CJNE A,#02H,LOOP3
S2:JNB P2.1,S2
CLR P2.0
MOV TL0,#07BH//0.7mSEC OFF to set delay angle for 0.7msec
MOV TH0,#0FDH
CALL DELAY
SETB P2.0
MOV TL0,#0A4H//0.1MSEC ON trigger for 100us
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TL0,#0E1H//9.2MSEC OFF
MOV TH0,#0DEH
CALL DELAY
LJMP MAIN
LOOP3:
CJNE A,#03H,LOOP4
S3:JNB P2.1,S3
CLR P2.0
MOV TL0,#0F6H//1.4MSEC OFF to set delay angle for 1.4msec
MOV TH0,#0FAH
CALL DELAY
SETB P2.0
MOV TL0,#0A4H//0.1MSEC ON trigger for 100us and so on
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TL0,#066H//8.5MSEC OFF
MOV TH0,#0E1H
CALL DELAY
LJMP MAIN
LOOP4:
CJNE A,#04H,LOOP5
S4:JNB P2.1,S4
CLR P2.0
MOV TL0,#71H//2.1MSEC OFF
MOV TH0,#0F8H
CALL DELAY
SETB P2.0
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TL0,#0ECH//7.8MSEC OFF
MOV TH0,#0E3H
CALL DELAY
LJMP MAIN
LOOP5:
CJNE A,#05H,LOOP6
S5:JNB P2.1,S5
CLR P2.0
MOV TL0,#0ECH//2.8MSEC OFF
MOV TH0,#0F5H
CALL DELAY
SETB P2.0
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TL0,#71H//7.1MSEC OFF
MOV TH0,#0E6H
CALL DELAY
LJMP MAIN
LOOP6:
CJNE A,#06H,LOOP7
S6:JNB P2.1,S6
CLR P2.0
MOV TL0,#66H//3.5MSEC OFF
MOV TH0,#0F3H
CALL DELAY
SETB P2.0
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TL0,#0F6H//6.4MSEC OFF
MOV TH0,#0E8H
CALL DELAY
LJMP MAIN
LOOP7:
CJNE A,#07H,LOOP8
S7:JNB P2.1,S7
CLR P2.0
MOV TL0,#0E1H//4.2MSEC OFF
MOV TH0,#0F0H
CALL DELAY
SETB P2.0
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TL0,#7BH//5.7MSEC OFF
MOV TH0,#0EBH
CALL DELAY
LJMP MAIN
LOOP8:
CJNE A,#08H,LOOP9
S8:JNB P2.1,S8
CLR P2.0
MOV TL0,#5CH//4.9MSEC OFF
MOV TH0,#0EEH
CALL DELAY
SETB P2.0
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TL0,#00H//5.0MSEC OFF
MOV TH0,#0EEH
CALL DELAY
LJMP MAIN
LOOP9:
CJNE A,#09H,LOOP10
S9:JNB P2.1,S9
CLR P2.0
MOV TH0,#0EBH
CALL DELAY
SETB P2.0
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TH0,#0F0H
CALL DELAY
LJMP MAIN
LOOP10:
CJNE A,#0AH,LOOP11
S10:JNB P2.1,S10
CLR P2.0
MOV TH0,#0E8H
CALL DELAY
SETB P2.0
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TL0,#066H//3.5MSEC OFF
MOV TH0,#0F3H
CALL DELAY
LJMP MAIN
LOOP11:
CJNE A,#0BH,LOOP12
S11:JNB P2.1,S11
CLR P2.0
MOV TH0,#0E6H
CALL DELAY
SETB P2.0
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TH0,#0F5H
CALL DELAY
LJMP MAIN
LOOP12:
CJNE A,#0CH,LOOP13
S12:JNB P2.1,S12
CLR P2.0
MOV TH0,#0E3H
CALL DELAY
SETB P2.0
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TH0,#0F8H
CALL DELAY
LJMP MAIN
LOOP13:
CJNE A,#0DH,LOOP14
S13:JNB P2.1,S13
CLR P2.0
MOV TL0,#66H//8.5MSEC OFF
MOV TH0,#0E1H
CALL DELAY
SETB P2.0
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TH0,#0FAH
CALL DELAY
LJMP MAIN
LOOP14:
CJNE A,#0EH,LOOP15
S14:JNB P2.1,S14
CLR P2.0
MOV TH0,#0DEH
CALL DELAY
SETB P2.0
MOV TH0,#0FFH
CALL DELAY
CLR P2.0
MOV TL0,#7BH//0.7MSEC OFF
MOV TH0,#0FDH
CALL DELAY
LJMP MAIN
LOOP15:
CJNE A,#0FH,LOOPE
S16:JNB P2.1,S16
CLR P2.0
MOV TL0,#00H//10MSEC OFF
MOV TH0,#0DCH
CALL DELAY
LJMP MAIN
LOOPE:
LJMP MAIN
DELAY:
SETB TR0
L1:JNB TF0,L1
CLR TF0
RET
END
Problems:
Queries:
Thanks in advance
