A uC that has an internal clock would eliminate external components; and you could set the clock to the lowest frequency to minimize power use (and thus heat dissipation) in the uC itself.
Operating the uC and LEDs with voltage that's about 10% over the rated Vf for the LEDs that you are using will help to keep heat dissipation down. Modern super-bright LEDs are VERY bright; you could probably run them on just a few mA current and still get a very convincing effect.
Don't forget that very thin PCB material is available; you can cut the stuff with scissors.
