RE: Show us how YOU use white LED's
Before I redesign the wheel the wheel again, I thought I should check first...
I'll be upgrading the headlamp to use two Luxeon Rebel Tri-Stars or Indus Cree XP-G
Stars, but with a boost driver so I don't have to double the battery pack cell count. Problem is I haven't found any 700ma or 1000ma constant current LED boost drivers, except for an Eval Kit which looks like it can run three tri-stars at 700 (1000ma after modification for the Rebels.)
The eval board is physically larger than the BuckPuck I'm currently using and it'll require a protective housing and possibly modification.
So, before I start making the enclosure and making other changes,does anyone know of any BoostPuck type products that support higher currents?
Thank you.
Thank you.
