The power supply is is switched on by jumping the 3rd and 7th pin together on a 6 pin conector. Once I disconect the jump wire it always turned totaly off but now it is still putting out 18-19volts. I can here the capacitor clicking on and off when I jump then unjump the switch. Jaclement the 19 volts are there with no strings of leds connected. If there is not a saftey issue of something burning up it would not be a problem the PS will be on a timer so it would have power cut to whole unit.
